I have an Ubuntu 22.04 system, and I want to calculate the Line Energy (LET) of all particles in the center target region of this geometry, specifically: the incident particle is a neutron, and the C1 geometry is set up with a B10-containing material that produces alpha, Li-7, and gamma particles through the reaction of the neutron with the B-10, and to count the LET of these particles at the target. However, I have a problem: when I use USRYIELD, the program reports an error after 1 cycle: FINISHED WITH ERRORS. however, when I use only USRBIN, the program calculates and plots normally, and I have checked the model and there should be no error, I don’t understand what’s the problem, can you help me?
Here are the relevant files:
