I am running some simulations loading a Fortran routine. Since several days ago, I have noticed that after loading the executable into the “Exe:” space in the bottom of Flair, saving the updates and clicking in “RUN” window, if I click back to “FLAIR” window the “Exe” space is empty again. Also if I run the simulation without check, the out file is in binary format.
I have compiled the routine again but it did not work. Do you have any idea what is happening? Does someone have the same issue?
Thank you for your reply. Yes, sorry I think I did not explain well. I meant just that I know that there is a problem with the routine because the out file is a binary file, so it is a clear sign to do not use the executable properly.
Could you tell me how can I run the newest version? Until now, I just wrote the commands “flair” and the “file.flair” I thought that the updates would run directly using that.
