Dear flair user,
I’m trying to download the neutron data in order to run Flair simulation, however I had follow the instructions from the website I wasn’t able to install it correctly, not too sure where is wrong in the terminal which it show error to open the file that I download from the website, hope someone will be able to help me, many thanks
Dear Kevin,
it seems that copying the tar file wasn’t successful, that’s why the tar command fails to open it.
Also, you should copy it to /deskop/fluka4-4.1 and not /desktop/fluka4-4.1/bin.
Dear Dávid,
I had changed the copy, however, it seems there is still an issue with copying the file.
Dear Kevin,
you are missing a space between the filename and the target directory.
Dear Dávid,
Thanks for pointing out that, I had successfully downloaded it, many thanks!
Best wishes,
Kevin
