Material does not cover the lattice side
I have a small-size strip that I duplicated using LATTICE, but it looks like the material does not completely cover the copied strip. Is it a problem with my code? Please advise. (Flair file is attached)
LATTICEmicro.flair (1.9 KB)
Also when I replicate the lattice, the uncovered part increases. Is it a problem with the code?
Thank you for the bug report. It doesn’t seem to be a problem with your code, but some problem in the transformation inside flair. We are looking at it
You are dealing with ultra small dimensions in your geometry 1e-6 cm ~= 10nm. So small that the simulation results can be questionable.
Flair to avoid the precision problems during the 3D ray tracing / lattice rendering it assumes a small epsilon of 1e-10cm at the starting position, which is what you are seeing in your image as the white strip
So, I assume this problem does dot exist in FLUKA itself. For example, If I replicate the object multiple times, and then run a transport simulation, will this problem (from the point of view of small scales) affect the simulation? or is it only the geometry views that I see in Flair?
I have another question:
Can the replicated copy be replicated again by LATTICE card, or LATTICE card works only on the original object?
Unfortunately not. You cannot have LATTICE of a LATTICE
You need always to replicate to the original object
