Meaning of Intensity and Bin Height in Source Routine Spectrum Files
Dear FLUKA Experts,
I want to implement X-ray source user routine with an external spectrum file, but I’m uncertain about some terminology:
For continuous spectra (Columns: Energy, Intensity):
1)Does “Intensity” represent the number of photons at each energy level (energy bin)?
For histogram spectra (Columns: Emin, Emax, dN/dE):
2) What exactly does the “Bin height” (dN/dE) represent? How does it differ from “Intensity” in the continuous spectra?
I’d greatly appreciate any help. Thank you!
Dear Marcin,
  1. No, if you have energy bins, (e_min and e_max are provided) then you have a histogram. If only one energy value is given for an intensity, then you can use the continuous spectrum.
  2. For a histogram spectrum, you need to give the number of particles/energy unit, which is how histograms are plotted. The source routine will calculate the total number of particles in each bin for the sampling.
Dear Dávid,
Thank you for your reply.
I want to make sure I understand correctly:
  1. If I have energy bins defined by minimum and maximum energy values (Emin, Emax), and for each bin, I provide a number of photons, then I’m working with a histogram spectrum. The source routine will calculate the actual number of particles in each bin based on this density.
  2. For continuous spectra, it’s essentially a function (that would be plotted as a smooth curve) defined by discrete pairs (Energy, Intensity), where each specific energy point has a corresponding intensity value.
Thank you for your help,
Marcin
Dear Marcin,
yes, those descriptions sound correct.
But to be sure, you can always add a scoring surface around the source location to score the energy distribution of the primaries. This should reproduce the you input spectrum/histogram.
