Hello David,
Thanks always for your feedback …
I did install Pillow as a user , i.e. pip3 install Pillow --user.
But the “chck_luka.py” produce a Warning and Error!
…Error:
{flukadir}/bin/lfluka -o testfluka doesn’t compile/link properly <<<<<
**Please ensure you have the correct version of fluka with the appropriate compiler**
I installed Fluka from “fluka-4-1.1.Linux-gfor9.x86_64.rpm”.
Thanks
Overall output:
$ /home/here/zzz-bkup02/check_fluka.py
Checking python
Version: 3.6-8 ok
Checking python tkinter module
tkinter found
Checking tk library
Tk Version= 8.6 ok
Checking python imaging
python-imaging-tk installed
Checking gnuplot
gnuplot 5.2.4 ok
Checking memory
Ram: 3825416 kb ok
Swap: 4157436 kb ok
Checking CPU
CPUs: 4 ok
Clock: 2394.45 MHz ok
Arch: x86_64
Checking X11
X11 dimension: 2333x992 ok
X11 depth: 24 ok
Checking flair
flair not in standard directory
flair directory: /home/here/flair
flair version: 3.1-8
Checking flair-geoviewer
flair version ok (same or higher than 3.0-7)
flair-geoviewer version 3.1-8
flair and geoviewer version match
Checking gfortran
============================== WARNING ==============================
gfortran fortran not found
Please install the latest gfortran version
Fedora, RedHast, Scientific Linux, CentOS, Suse:
dnf -y install gfortran
Ubuntu:
apt install gfortran
MacOS (Macport recommended):
port install gcc9
Checking FLUKA
FLUKA directory: /usr/local/fluka
FLUKA Version= 4-1.1
/usr/local/fluka/bin/fluka exists
/usr/local/fluka/bin utilities exists ok
============================== ERROR ==============================
[fernando@acnlinhe fluka-test3]$ /home/here/zzz-bkup02/check_fluka.py
Checking python
Version: 3.6-8 ok
tkinter found
Checking tk library
Tk Version= 8.6 ok
Checking gnuplot
gnuplot 5.2.4 ok
Checking memory
Ram: 3825416 kb ok
Swap: 4157436 kb ok
Checking CPU
CPUs: 4 ok
Arch: x86_64
Checking X11
X11 depth: 24 ok
Checking flair
Checking gfortran
Ubuntu:
port install gcc9
Checking FLUKA
Thanks
Arthur
