Missing negative values in 2D projection
FLUKA: 4-5.2
Flair: 3.4-5.4
Operating system: Ubuntu 24.04 LTS
I am trying to understand charge flow via a NET-CHRG usrbin, but a 2D projection shows values of 0 where the most action should happen (Z=570-590, y = ±2.5-3.0).
when I try to get the 1Dmin and 1Dmax, negative values appear to be there
but a 2D(Z) projection at the most negative peak shows a minimum of 0.
It seems the negative values are lost somewhere in the post-processing.
data in question:
protons_hloss_22.bnn.txt (1.5 MB)
Roman
Dear Roman,
Thank you very much for reporting the issue.
Until it is fixed (or instead of the standard plotting) you can plot correctly the negative charge values on the Gemometry tab using a Layer.
Furthermore if you set the Palette color to diff instead of fluka, you can easily distinguish the negative and positive values (in case the min and max of the palette are set to have the same absolute value).
