(I had posted about what follows as a reply to my own post about another issue. However, since I’m not able to change the title of that post, I’m opening a new one with a more relevant title. I hope this does not violates the forum rules.)
I’ve written a Flair project to simulate a 3 MeV electron beam (Gaussian cross section with sigma = 1 mm) propagating through a 6 mm diameter hole in a Cu screen (to roughly replicate the exit of a linac) and then through a 50 um thick Ti window. Then the beam propagates for a certain distance in air (some centimeters). I would like to detect its energy spectrum and its fluence cross section. I’ve defined USRBDX and USRBIN detectors for that and I get reasonable results for the energy spectrum and the fluence (BEAMPART) profiles along x and y. However, the z-projected 2D plotting of BEAMPART belonging to the same USRBIN of the working x and y profiles gives a PLOTGEOM.STORE missing file error. Can you please help? Please find below the project files.
Thank you in advance,
Enrico.
ele3MeV Gaussiana troncata.flair (4.2 KB)
ele3MeV Gaussiana troncata.inp (2.4 KB)
