Dear Fluka experts,
I am following the steps to install the FluDAG tool. I am trying to install MOAB using the package manager install route written on https://svalinn.github.io/DAGMC/install/dependencies.html page. In particular, when I write this command
Thank you for your reply. I partially solved the problem. Now, I have this problem:
rm: cannot remove 'src/moab/EntityHandle.hpp': Too many levels of symbolic links
mv: failed to access 'src/moab/EntityHandle.hpp': Too many levels of symbolic links
config.status: error: could not create src/moab/EntityHandle.hpp
You could delete the MOAB directory with rm -rf MOAB, then repeat the installation process under the ‘MOAB Installation’ section of the link you provided and see if the same error persists.
Apparently, I have solved the issue. However, when I use $ which h5ls $ which mbconvert it doesn’t give me any output. So, maybe it hasn’t been installed?
This because when I go to the 2nd step to configure FluDAG
-- CMAKE_BUILD_TYPE not specified, defaulting to Release
-- CMAKE_BUILD_TYPE: Release
CMake Error at cmake/FindMOAB.cmake:7 (string):
string sub-command REPLACE requires at least four arguments.
Call Stack (most recent call first):
CMakeLists.txt:57 (find_package)
CMake Error at cmake/FindMOAB.cmake:17 (message):
Could not find MOAB. Set -DMOAB_DIR=<MOAB_DIR> when running cmake or use
the $MOAB_DIR environment variable.
-- Configuring incomplete, errors occurred!
See also "/home/lovepreet/dagmc_bld/DAGMC/bld/CMakeFiles/CMakeOutput.log".
So, I think there has been a problem during the installation.
UPDATE:
I tried the other way with the source and the previous command seems to work. However, I have these errors:
CMake Error: CMake can not determine linker language for target: pyne_dagmc-shared
CMake Error in src/pyne/CMakeLists.txt:
Exporting the target "pyne_dagmc-shared" is not allowed since its linker
language cannot be determined
CMake Error: CMake can not determine linker language for target: pyne_dagmc-static
Exporting the target "pyne_dagmc-static" is not allowed since its linker
CMake Error: Cannot determine link language for target "pyne_dagmc-static".
CMake Error: Cannot determine link language for target "pyne_dagmc-shared".
-- Generating done
-- Build files have been written to: /home/lovepreet/dagmc_bld/DAGMC/bld
I am using the CERN branch from ‘makeclean’ and not the one from ‘svalinn’. Replacing the associated commands of the installation guide with the ones I provide below should clone CERN’s branch by makeclean.
$ mkdir DAGMC
$ cd DAGMC
$ git clone https://github.com/makeclean/DAGMC.git
$ cd DAGMC
$ git checkout fluka-cern
I also have to add that I am a novice in DAGMC, perhaps other more experienced users in the forum can offer more help if needed.
-- The C compiler identification is GNU 7.5.0
-- The CXX compiler identification is GNU 7.5.0
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Found Git: /usr/bin/git (found version "2.17.1")
-- Submodule update
Submodule 'src/pyne/pyne' (https://github.com/pyne/pyne) registered for path 'src/pyne/pyne'
Cloning into '/home/lovepreet/dagmc_bld/DAGMC/DAGMC/src/pyne/pyne'...
Submodule path 'src/pyne/pyne': checked out '860d98371a810912b86d7f353477734b24506f33'
-- MOAB_CMAKE_CONFIG: /home/lovepreet/dagmc_bld/MOAB/lib/cmake/MOAB/MOABConfig.cmake
-- HDF5: Using hdf5 compiler wrapper to determine C configuration
-- Found HDF5: /home/lovepreet/dagmc_bld/HDF5/lib/libhdf5.so;/usr/lib/x86_64-linux-gnu/libz.so;/usr/lib/x86_64-linux-gnu/libdl.so;/usr/lib/x86_64-linux-gnu/libm.so (found version "1.8.13")
-- HDF5_INCLUDE_DIRS: /home/lovepreet/dagmc_bld/HDF5/include
-- HDF5_LIBRARIES_SHARED: /home/lovepreet/dagmc_bld/HDF5/lib/libhdf5.so;/usr/lib/x86_64-linux-gnu/libz.so;/usr/lib/x86_64-linux-gnu/libdl.so;/usr/lib/x86_64-linux-gnu/libm.so
-- HDF5_LIBRARIES_STATIC: /home/lovepreet/dagmc_bld/HDF5/lib/libhdf5.a;/usr/lib/x86_64-linux-gnu/libz.a;/usr/lib/x86_64-linux-gnu/libdl.a;/usr/lib/x86_64-linux-gnu/libm.a
-- MOAB_INCLUDE_DIRS: /home/lovepreet/dagmc_bld/MOAB/include;/home/lovepreet/dagmc_bld/HDF5/include;/home/lovepreet/dagmc_bld/HDF5;/usr/include/eigen3
-- MOAB_LIBRARY_DIRS: /home/lovepreet/dagmc_bld/MOAB/lib
-- MOAB_LIBRARIES_SHARED: /home/lovepreet/dagmc_bld/MOAB/lib/libMOAB.so
-- MOAB_LIBRARIES_STATIC: /home/lovepreet/dagmc_bld/MOAB/lib/libMOAB.a
-- Found MOAB
-- Found OpenMP_C: -fopenmp (found version "4.5")
-- Found OpenMP_CXX: -fopenmp (found version "4.5")
-- Found OpenMP: TRUE (found version "4.5")
-- Building shared executables
-- INSTALL_RPATH_DIRS: /home/lovepreet/dagmc_bld/DAGMC/lib
-- CMAKE_C_FLAGS:
-- CMAKE_CXX_FLAGS:
-- CMAKE_Fortran_FLAGS:
-- CMAKE_C_FLAGS_RELEASE: -O3 -DNDEBUG
-- CMAKE_CXX_FLAGS_RELEASE: -O3 -DNDEBUG
-- CMAKE_Fortran_FLAGS_RELEASE:
-- CMAKE_C_IMPLICIT_LINK_LIBRARIES:
-- CMAKE_CXX_IMPLICIT_LINK_LIBRARIES: stdc++
-- CMAKE_Fortran_IMPLICIT_LINK_LIBRARIES:
-- CMAKE_EXE_LINKER_FLAGS:
-- Building gtest
-- Building library: dagmc
-- LINK LIBS: /home/lovepreet/dagmc_bld/MOAB/lib/libMOAB.so;/home/lovepreet/dagmc_bld/HDF5/lib/libhdf5.so;/usr/lib/x86_64-linux-gnu/libz.so;/usr/lib/x86_64-linux-gnu/libdl.so;/usr/lib/x86_64-linux-gnu/libm.so
-- Building executable: pt_vol_test
-- Building executable: ray_fire_test
-- Building executable: test_geom
-- Building unit tests: dagmc_unit_tests
-- Building unit tests: dagmc_pointinvol_test
-- Building unit tests: dagmc_rayfire_test
-- Building unit tests: dagmc_simple_test
/home/lovepreet/dagmc_bld/DAGMC/src/src/pyne/amalgamate_pyne.sh: line 12: python: command not found
-- PyNE AMALGAMATION FAILED: 127
-- Building library: pyne_dagmc
-- LINK LIBS: /home/lovepreet/dagmc_bld/HDF5/lib/libhdf5.so;/usr/lib/x86_64-linux-gnu/libz.so;/usr/lib/x86_64-linux-gnu/libdl.so;/usr/lib/x86_64-linux-gnu/libm.so;/home/lovepreet/dagmc_bld/MOAB/lib/libMOAB.so
-- Building library: uwuw
-- LINK LIBS: dagmc-shared;pyne_dagmc-shared
-- Building executable: uwuw_preproc
-- Building unit tests: uwuw_unit_tests
-- Building unit tests: uwuw_unit_tests_tally
-- Building unit tests: uwuw_unit_tests_preprocessor
-- Building library: dagtally
-- Building unit tests: test_KDEKernel
-- Building unit tests: test_KDEMeshTally
-- Building unit tests: test_KDENeighborhood
-- Building unit tests: test_PolynomialKernel
-- Building unit tests: test_Quadrature
-- Building unit tests: test_CellTally
-- Building unit tests: test_TallyEvent
-- Building unit tests: test_TallyData
-- Building unit tests: test_TrackLengthMeshTally
-- Building executable: build_obb
-- Building library: makeWatertight
-- Building executable: make_watertight
-- Building executable: check_watertight
-- Building unit tests: make_watertight_cylinder_tests
-- Building unit tests: make_watertight_cone_tests
-- Building unit tests: make_watertight_no_curve_sphere_tests
-- Building unit tests: make_watertight_sphere_n_box_test
-- FLUKA_LIBRARIES: FLUKA_LIBRARIES-NOTFOUND/libfluka.a;gfortran
-- Found Fluka
-- Building library: fludag
-- LINK LIBS: FLUKA_LIBRARIES-NOTFOUND/libfluka.a;gfortran;dagmc-shared;pyne_dagmc-shared;uwuw-shared
-- Building executable: mainfludag
-- Building unit tests: fludag_unit_tests
-- Building executable: overlap_check
-- Building unit tests: overlap_check_test
-- DAGMC cmake config file: /home/lovepreet/dagmc_bld/DAGMC/lib/cmake/DAGMCConfig.cmake
-- DAGMC cmake version file: /home/lovepreet/dagmc_bld/DAGMC/lib/cmake/DAGMCConfigVersion.cmake
-- Configuring done
CMake Error at cmake/DAGMC_macros.cmake:246 (add_library):
Cannot find source file:
/home/lovepreet/dagmc_bld/DAGMC/src/src/pyne/pyne.cpp
Tried extensions .c .C .c++ .cc .cpp .cxx .m .M .mm .h .hh .h++ .hm .hpp
.hxx .in .txx
src/pyne/CMakeLists.txt:30 (dagmc_install_library)
-- Generating done
Thanks for repling @horvathd - I replied to the email, but it seems email replies dont get through to the forum
Another possibility is that python is installed, but for whatever reason you dont have a symbolic link to /usr/bin/python, in which case create one to /usr/bin/python3
As @nnikolop said, your FLUPRO variable isnt pointing to the right place, you need to point it to your fluka-cern directory, on my system for example its /home/adavis/opt/fluka-cern/fluka-4.0.1
unknown file: Failure
C++ exception with description "std::bad_alloc" thrown in the test body.
[ FAILED ] FluDAGMetaDataTest.CheckAssignMatsLegacy (533636 ms)
[----------] 1 test from FluDAGMetaDataTest (533638 ms total)
[----------] Global test environment tear-down
[==========] 4 tests from 2 test cases ran. (533743 ms total)
[ PASSED ] 3 tests.
[ FAILED ] 1 test, listed below:
1 FAILED TEST
I am writing to inform that I managed to install FluDAG and maybe it will be useful for someone. The problem was caused by the fact that the FLUPRO variable addressed to the position where libfluka.a was present, however, that directory did not contain FLUKA. So, I copied libfluka.a at the position where FLUKA was present, and FLUPRO addressed them both.
