Modeling a Blackbody Spectrum in FLUKA
FLUKA: 3.4-5.2
Flair:
Hello all,
I am trying to model a blackbody emitter in flair and score the photon counts on a detector. I think I’ve got the detector modeling down, but how would I model the source? Lets say I am modeling something like the sun’s emission spectrum seen at sea level, is there a way to properly do this in flair? Or do I need to write a source routine or something like that, if so, could I get some literature on that?
Here’s an image to better visualize what I mean by a blackbody spectrum emitted by the sun. I am trying to emit a large, continuous, spectrum of photons over an area.
(This is to measure UV photons of a specific range for a senior capstone project for background on a detector)
Any help is appreciated! The attached input file is our simulated thorium source and the UV-fluorescence it causes being measured by some PMTs at varying distances, if theres any improvements I can make there let me know!
ButtonTH-230.inp (3.5 KB)
Dear Daniel,
Thank you for your question.
From a conceptual viewpoint, you could write a source routine in which you set the energy of your optical photon according to the desired distribution. If you have a mathematical formulation describing the spectrum, you could use it directly for sampling. Sampling from a histogram of the same distribution would be another possible approach.
Here you will find some material to get started with source routines:
Regarding the physics of the simulation itself, please make sure to check the current capabilities and limitations of FLUKA for optical photons. The following material should help clarify them:
Hope this helps,
Tommaso
