I want to define 4 different regions of a simulation geometry as source. Each region has equal probability.
I used following kind of syntax in the new generation source.f (see the attached).
random = FLRNDM(XDUMMY)
if (random .lt. 0.25) then
call regionsource ( coordinate_x, coordinate_y, coordinate_z, 35, 7.5D0, 14.0D0, 1.8D0, 4.2D0, 31.5D0, 42.0D0 )
else if (random .gt. 0.25 .AND. random .lt. 0.5) then
call regionsource ( coordinate_x, coordinate_y, coordinate_z, 23, 5.5D0, 7.5D0, 0.5D0, 1.1D0, 28.0D0, 31.0D0 )
else if (random .gt. 0.5 .AND. random .lt. 0.75) then
call regionsource ( coordinate_x, coordinate_y, coordinate_z, 28, 2.0D0, 3.0D0, 0.3D0, 0.5D0, 25.0D0, 27.0D0 )
else
call regionsource ( coordinate_x, coordinate_y, coordinate_z, 30, 1.0D0, 1.5D0, 0.1D0, 0.25D0, 20.0D0, 24.0D0 )
end if
Here region number, and Xmin, Xmax, Ymin, Ymax, Zmin and Zmax values are arbitrarily put. It will be modified as per the actual simulation geometry.
Kindly suggest me whether the syntax is correct? If not, kindly suggest me some way out.
Thanking you in advance.
source_newgen_with_Multiple_regionsource.f (20.2 KB)
