I am trying to define a simple neutron source in water using the old source routine,
but I get the error “Program received signal SIGFPE: Floating-point exception - erroneous arithmetic operation”.
When I switch the surrounding material to Lead or switches off the source routine the error does not appear.
What should I add to the source routine?
Please refer to the attached files.
* | Kinetic energy of the particle (GeV)
TKEFLK (NPFLKA) = 1.0D-3
* TKEFLK (NPFLKA) = SQRT ( PBEAM**2 + AM (IONID)**2 )
* & - AM (IONID)
* | Particle momentum
PMOFLK (NPFLKA) = PBEAM
The two instructions are incompatible: in your input file you specify a 2 MeV neutron energy. Therefore, you need to decide where you set the energy. Assuming you want to set it in the source file, you need to write the following:
