Hello FLUKA experts,
I want to simulate an x-ray source of 6MeV. The beam at a distance of 3m from the source is a rectangular of 1.7mX0.002m. (very thin and very wide)
I also know that the dose rate is 8Gy/min at distance 1m from the source. The leakage is 2.0E-5.
I need to calculate the dose rates when I put this source in a room.
I wanted to use USRBIN to get the does rates at 1m so I can normalize it to 8Gy/min. But the results I get from the USRBIN change when I change the number of bins.
When I use a point source or even the same source but with a big square width instead (1mX1m) the change in the bins will change only the resolution of the results (as expected).
My guess is that my bins are not small enough, but in order to increase the number of bins I need to measure a smaller area. Which is a problem, because at the end I need to put the source in a room and measure the dose rates everywhere.
I’m not sure how to proceed. How should I normalize my source?
Attached my files
Many thanks in advance,
Yael
XrayBeam.flair (6.5 KB)
XrayBeam.inp (1.5 KB)
BeamSource.f (9.3 KB)
spec.dat (2.0 KB)
