Hi I am not able to solve the OPEN PGP error, in UBUNTU 20.04. I am getting the same error.
I have tried copying and pasting from the flair site the PUBLIC KEY, suggested in the previous comments but it doesn’t seem to work. I have also installed and disinstalled, ubuntu, resetting, I must have say I have tried it all, I am desperate and don’t know what to do.
Dear William,
could you be more specific?
- What is the actual error message?
- Which commands are you using and what is their output?
- Are you using WSL on Windows or a native Ubuntu installation?
Dear William,
could you tell me what is the output of the following command?
wget -O - https://cern.ch/flair/download/ubuntu/KEY.gpg
Dear William,
it seems your Anti-Virus / Firewall software replaces the SSL certificate of CERN with it’s own, which doesn’t work with the wget command.
You may try to disable this feature, or you can modify the setup script replacing
wget -q -O - https://cern.ch/flair/download/ubuntu/KEY.gpg | apt-key add -
with
wget -q -O - http://cern.ch/flair/download/ubuntu/KEY.gpg | apt-key add -
Dear William,
the command works, as you can see from the OK line. What you need to do is to edit the setup_wsl.sh script to have this line, instead of the original one.
I’m not familiar with this anti-virus software, so I can’t help with the option you need to turn off.
Sorry, I didn’t quite get the “edit the SETUP_WSL.SH LINE to have this line”, part.
Dear William,
you can open the setup_wsl.sh bash script with a text editor, and edit the line there. After that try to run it again.
THANK YOU VERY MUCH SIR, I have solved the problem !
