I am implementing a simulation for the generation of scintillation photons in an optical fiber with 1 mm diameter and 1 m long. The scintillating (optical) will be produced by the excitation of an external source. In a first attempt, I am using electrons of 2.28 MeV impinging at a 45º angle laterally.
The fiber is made of polystyrene and is placed in air. The materials have the following optical properties (OPT-PROP):
AIR: n=1, no attenuation
POLYSTR: n=1.59, Attenutaion length = 400 cm (0.0025 cm^-1)
Since the scintillation emission range is between 400 and 600 nm, with a maximum at 450 nm, I placed a card with WV-LIMIT with these parameters for each material. I also introduced a card for quantum efficiency (SENSITIV) of 33% (0.33).
Regarding scintillation production (OPT-PROD/SCINT-WV), I am considering only emission in polystyrene with the following parameters:
Single emission: 450 nm (2.8 eV)
Decay time: 2.8 ns
fraction = 2.8E-6 MeV x 12 000 photons/MeV = 0.033.
The Cerenkov radiation is switched off for the moment.
About scoring, I am only considering now three USERBIN (in bin format) to obtain the spatial distribution of the fluence of electrons, photons, and optical photons in the fiber and around it. I am using PRECISIO defaults and have not implemented any bias or cuts.
Even with only 1000 primaries, the simulation takes a long time and hangs in 1st cycle. With 10 primaries I was able to complete the simulation, but when processing the five cycles I get the message:
At line 239 of file usbsuw.f
Fortran runtime error: Index ‘81000000’ of dimension 1 of array ‘gmstor’ outside of expected range (60000000:1)
When I tried a larger volume of scintillating material (I tried with a 4 cm x 4 cm x 4 cm polystyrene box), it could not even complete the first cycle after 48 hours. I believe I am producing too many scintillating photons and I would like some help on how I can optimize the simulation… (inp file: electronfibre.inp (2.0 KB) )
Thanks in advance,
Jorge Miguel Sampaio
