I am running simulations where I send an electron beam into a thick aluminum target to obtain photo-produced muons near beam energy, sampling them on a surface ~1m around the target.
I am biasing the interaction length of the photons by 10^-5 to produce more muons. Moreover, as I am interested in higher-energy muons, I am also using leading particle bias to reduce CPU time.
I also did the following to stretch the spectrum of the muons produced:
- Simulating 10^8 primaries, in this way I get good statistics of muons up to ~9.6 GeV.
- Make a new simulation increasing all energy cuts to 9.6 GeV and stopping everything after my sampling surface.
- With this, I greatly reduce the average time needed to simulate a primary, and I am able to simulate 10^11/10^12 electrons and get muons up to ~10.4 GeV
- “Stich” the two results together.
However, repeating this process and increasing the energy cuts to 10.4 GeV does not help because the average time needed to simulate a primary does not change much. Also, increasing the number of primaries and/or the biasing to the interaction length makes the simulation time too big.
So, I wanted to ask if you know/can suggest some other method/technique to increase the number of muons with energy close to the beam without exponentially increasing the simulation time.
