I’m trying to activate the pointwise neutron cross section for BORON-10 in the thermal neutron region, since I’m interested in the 478keV emitted due to neutron capture. The pointwise cross section of B-10 should be present according to table 10.5.5 in the Manual. In my simulation, I set DEFAULT to PRECISIOn and I added a LOW-NEUT card with WHAT(6)=4.
The following are the scoring using USRTRACK, in which you can see that the interested gamma is not monoenergetic. I would expect it to be monoenergetic at 478 keV, am I wrong?
The output says that the only pointwise cross section activated is the H-1 one:
I thought about using LOW-PWXS card but it looks like it’s not supported by Flair. Is there a way to check if the B-10 pointwise cross section is engaged correctly?
Thank you in advance,
Giacomo
DETECT + RADDECAY tests.inp (4.0 KB)
