Is it possible to pass arguments to the postrprocessing programs?
For example: $FLUPRO/flutil/usbsuw INPUT1 INPUT2 INPUT3 OUTPUT
Thanks in advance,
Szabolcs
Thanks in advance,
Szabolcs
Kedves Szabolcs,
First of all, with the CERN version of FLUKA you can call the post processing programs directly, as their folder is included in your $PATH. ($FLUPRO/flutil/ is the obsolete location of these programs)
Unfortunately you can’t pass arguments to these scripts, but it is possible to create a text file (input_file
) containing the fort files you want to process and the name of the desired output file (without the extension). For example:
run001_fort.21
run002_fort.21
run003_fort.21
output_filename
Then you can feed this file to the post processing programs via the standard Linux pipes:
usbsuw < input_file
I hope this helps.
Üdv.:
Dávid
Kedves Dávid,
This is a brilliant idea! It is perfect to me.
Thank you for your help.
Üdv,
Szabolcs
