Precompiled FLUKA executable with DPMJET and RQMD
Dear Fluka experts
I was working on the activation’s pdf in the 21st fluka course. I can’t run the .inp file properly. Maybe, I can’t add DMPJET and RQMD? so how can I add and run it correctly?What does mean error code 1 ? I could not find it the meaning.
regards
ex_Activation.inp (4.3 KB) ex_Activation.out (636 Bytes)
Dear @demirukiye,
according to the output file you try to use ldpmqmd as the FLUKA executable. However it is just a linker scripts, used to compile custom FLUKA executable with DPMJET and RQMD linked. The standard executable containing those modules is called flukadpm located in the same folder.
