Dear FLUKA and Flair experts,
I am trying to install the Flair 3.0-2 released recently. I have installed FLUKA 2011.3.0 and Flair 3.0-1 on ZorinOS (based on Ubuntu 18.04 LTS). I just uninstalled flair 3.0-1 and then tried to install the 3.0-2 version. However, when I made with the .deb package, the following problem appeared:
$ sudo dpkg -i flair_3.0-2_all.deb
Selecting previously unselected package flair.
(Reading database … 306281 files and directories currently installed.)
Preparing to unpack flair_3.0-2_all.deb …
Unpacking flair (3.0-2) …
dpkg: dependency problems prevent configuration of flair:
flair depends on flair-geoviewer; however:
Package flair-geoviewer is not installed.
dpkg: error processing package flair (–install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
flair
And when I tried to install geoviwer first, the following problem appreared:
$ sudo dpkg -i flair-geoviewer_3.0-2_ubuntu18.04_amd64.deb
Selecting previously unselected package flair-geoviewer.
(Reading database … 307220 files and directories currently installed.)
Preparing to unpack flair-geoviewer_3.0-2_ubuntu18.04_amd64.deb …
Unpacking flair-geoviewer (3.0-2) …
dpkg: dependency problems prevent configuration of flair-geoviewer:
flair-geoviewer depends on flair (= 3.0-2); however:
Package flair is not configured yet.
dpkg: error processing package flair-geoviewer (–install):
flair-geoviewer
It looks like Flair and geoviewer depends on each other and either first installed will trigger dependency problem from the other.
So, how to deal with this problem?
