Problem in running example
FLUKA:4-5.1
Flair:
Operating system: macOS
Compiler:
Hello,
I am a beginner user of FLUKA. I have installed FLUKA and tried to run one of the example input files from the FLUKA examples library. but the simulation gets stuck at cycle 1 and does not progress even with a very low number of primary histories (START 100). I have waited for more than an hour with no change in the output. so I am kind asking for advice to solve it.
gcrexampleAllParticle.inp (3.9 KB)
Dear Tahany,
Please upload the .out, .log, and .err files to see the error message you are getting. They may be located in a fluka_xxxxx directory.
Thank you for your kind reply!
in the .log file I got this massage
“Program received signal SIGILL: Illegal instruction. Backtrace for this error: Program received signal SIGBUS: Access to an undefined portion of a memory object. “
After checking my setup, I realized that I was using gfortran 15, which wasn’t compatible with the FLUKA version I am running. I switched to gfortran 13, and the issue was resolved successfully.
Thank you very much for your time and consideration.
Tahany
Hi @tabdelha ,
There shouldn’t be any issues with GFortran 15.
Could you please provide the output of these commands, so we can investigate this issue further?
uname -a
sw_vers -productVersion
gfortran -v
echo $PATH
port echo requested
port select --summary
Thank you
Hello Luigi,
Here are the outputs of the commands you requested. please check and let me know if you need further details:
uname -a
Darwin Tahanys-MacBook-Pro.local 23.5.0 Darwin Kernel Version 23.5.0: Wed May 1 20:19:05 PDT 2024; root:xnu-10063.121.3~5/RELEASE_ARM64_T8112 arm64
14.5
package-id: com.apple.pkg.CLTools_Executables
version: 15.3.0.0.1.1708646388
volume: /
install-time: 1710605945
gfortran -v
Using built-in specs.
COLLECT_GCC=gfortran
COLLECT_LTO_WRAPPER=/opt/homebrew/Cellar/gcc/15.2.0/bin/../libexec/gcc/aarch64-apple-darwin23/15/lto-wrapper
Target: aarch64-apple-darwin23
Configured with: ../configure --prefix=/opt/homebrew/opt/gcc --libdir=/opt/homebrew/opt/gcc/lib/gcc/current --disable-nls --enable-checking=release --with-gcc-major-version-only --enable-languages=c,c++,objc,obj-c++,fortran,m2 --program-suffix=-15 --with-gmp=/opt/homebrew/opt/gmp --with-mpfr=/opt/homebrew/opt/mpfr --with-mpc=/opt/homebrew/opt/libmpc --with-isl=/opt/homebrew/opt/isl --with-zstd=/opt/homebrew/opt/zstd --with-pkgversion=‘Homebrew GCC 15.2.0’ --with-bugurl=GitHub · Where software is built --with-system-zlib --build=aarch64-apple-darwin23 --with-sysroot=/Library/Developer/CommandLineTools/SDKs/MacOSX14.sdk
Thread model: posix
Supported LTO compression algorithms: zlib zstd
gcc version 15.2.0 (Homebrew GCC 15.2.0)
port echo requested
gcc12 @12.4.0_2+stdlib_flag
gcc13 @13.4.0_1+stdlib_flag
gcc_select @0.1_10
py311-numpy @2.3.4_0+accelerate+gfortran
py311-Pillow @9.5.0_1
py311-tkinter @3.11.14_0
python311 @3.11.14_0+lto+optimizations
Name Selected Options
gcc mp-gcc13 mp-gcc12 mp-gcc13 none
python python311 python311 none
python3 none python311 none
Best wishes,
Tahany
Dear @tabdelha,
You’re using a mixed environment with MacPorts and Homebrew which can cause issues with the FLUKA/Flair problem as discussed in several forum threads.
I believe the original issue with gfortran15 was related to this. Generally, it’s better to have a single package manager or clearly separate environments as outlined here:
Best, Luigi
