Dear amario,
Thanks for your help,I have defined the geometry. I want to record the energy deposition in the geometry I created, but the result shows that there is no energy deposition.
There is energy deposition in the whole region(23 BIN), but there is no energy deposition in the created geometry(21 BIN and 22 BIN).Please help me see if there is a problem with the geometry I created. E.flair (2.1 KB)
The problem is due to the fact that you are applying the wrong transformation to the USRBIN. You are applying the same ROT-DEFI you used to transform the geometry while instead you should apply the inverse transformation. Have a look at this picture where I compared the use of direct with the inverse transformation for the two scoring you defined:
