when i use the voxel card,it finished with wrong.The output shows:
Abort called from VXLINP reason UNABLE TO OPEN VOXEL FILE Run stopped!
STOP UNABLE TO OPEN VOXEL FILE
I don’t know how to work it out.Can anyone helps me?
Thank you!!
Thank you!!
And it sometimes sends this message:
Abort called from VXLBDY reason NO NR_TH VOXEL FOUND Run stopped!
STOP NO NR_TH VOXEL FOUND
Dear @ye.jiaquan is it possible to provide us the necessary files to debug the problem
proton1.13.inp (1.2 KB)
of course,the .inp and .voxel is attached
Hi @ye.jiaquan
the problem is that in the original dicom there is a hounsfield unit that doesn’t have any voxel associated. Flair despite this unit is not referred anywhere it creates the VOXEL042 which is empty.
I am looking to find which is the best approach to solve the issue, either from the side of flair or fluka.
Vasilis
Hi @ye.jiaquan
could you re-create the voxel file with the latest flair version 3.1-5 which should be more robust in constructing the voxel file.
