Producing 1.6 TB files and run stops due to low storage
Kindly see the attached files which are .flair, .inp, .err, .log and .out.
The files is running succesfully for 1 or 2 cycles. Then it stops due to low storage space in the computer. I have checked the size of the file after running of 2 cycles is ~ 1.6 TB which is very impractical.
It seems that there is some error in the input files but I am not able to detect that.
Any help will be beneficial for me.
Thanking you in advance.
carbon_ion.flair (5.9 KB)
carbon_ion.inp (5.6 KB)
carbon_ion_04001.log (12.9 KB)
carbon_ion_04001.err (28.9 KB)
carbon_ion_01.out (3.0 KB)
The source files for the above are uoloaded here for your reference.
SOBP_carbon_1.dat (1.9 KB)
source_newgen.f (19.4 KB)
are uploaded here
input_files.zip (14.0 KB)
[/quote]
Dear Arghya,
I can’t reproduce the issue, can you tell me which files grow unlimited?
Case 1: When I am running for monoenergetic carbon ions, it is running smoothly.
Case 2: When I am compiling the source.f file, and running the file with less number of histories ~ 1E5, it is running without any error but uncertainty is large. To, reduce the uncertainty, When I am making the histories ~ 1.6E9 (as in the case of attached input files), the error is occurring i.e after 2 cycles, run stops showing low storage space.
Dear Arghya,
there was a bug in the annular sampling in the source_newgen.f routine a few years back. Please update your routine to the latest version.
Thank you very much for your reply. So I need to take the latest source_newgen.f routine (as attached). Am I correct ?
The syntax is: call sample_annular_distribution( 0.0D0, 0.001D0, coordinate_x, coordinate_y )
This is for FLUKA version 4-3.0
Or, how to update the routine?
Any clue will be helpful to me.
Dear Arghya,
you need to take source_newgen.f from the latest FLUKA release, and copy over the changes you made. The syntax of the routine did not change.
Edit: Please, don’t forget to recompile your executable after changing the user routine.
