Dear Fluka experts,
I have a doubt about which energy unit i have to use in the read_phase_space_file function.
The process I use to create the phase space file is the following:
- Run a simulation using an electron beam
- Sample neutrons on a surface
- Create a ROOT multi dimensional histogram (THnSparse) with the variables needed for the phase_space_file
- Use the function GetRandom to regenerate the distributions and print a phase space file
On step 3 I fill the histogram with the variable PTRACK from the file TRACKR, obtained from a custom mgdraw.f
Here 5.3. Physical units — FLUKA Manual I read that the energy unit of this variable should be GeV/c.
My doubt arises from the fact that “energy_logical_flag” variable is false by default. So, by default, in the second column of my phase space file I have to put a momentum.
So, what energy unit should I put in read_phase_space_file if energy_logical_flag=.false. considering that I already have a momentum in GeV/c?
I ask this because I had the doubt that maybe when the variable is set to false it automatically convert the second column to a momentum, and in this case I only have to put GeV as unit.
Sorry if the question seems stupid but I can’t figure it out by myself.
Thanks in advance,
Antonino
