I have two sets of simulations: ones disregarding Cherenkov radiation and others regarding Cherenkov radiation.
For some reason, the simulations without Cherenkov run but the simulations with Cherenkov give me a RC=136 error.
The files are the same with the exception of the Cherenkov card (attached)…
The problem is related to the OPT-PROD, Type/SDUM = SENSITIV card.
To circumvent the bug, you need to the set the max sensitivity parameter by hand (Default = 1.0)
Furthermore, the 2nd parameter is not used, I assume you wanted to set the 3rd parameter.
