Hi,
I am using a number of REC bodies in my geometry, which I have entirely constructed with the Geometry editor in FLAIR (I have not modified the numerical values manually).
I systematically get an abort for geometry errors, claiming that the axes are not perpendicular.
REC body77 155 -0.21400000D+04 -0.34961494D+02 -0.38700000D+04 -0.61743040D+03 0.00000000D+00 -0.35144076D+02 1567
-0.11542813D+02 0.00000000D+00 0.20279047D+03 0.00000000D+00 -0.21374486D+03 0.00000000D+00
REC body78 156 -0.21400000D+04 -0.34961494D+02 -0.38700000D+04 -0.61743040D+03 0.00000000D+00 -0.35144076D+02 1583
-0.99440823D+01 0.00000000D+00 0.17470309D+03 0.00000000D+00 -0.17371812D+03 0.00000000D+00
REC body79 157 -0.24985958D+04 -0.34961494D+02 -0.38722500D+04 -0.88261980D+03 0.00000000D+00 -0.32692274D+03 1599
-0.70551077D+02 0.00000000D+00 0.19047245D+03 0.00000000D+00 -0.21374486D+03 0.00000000D+00
Abort called from BODYGN reason REC HEIGHT NOT PERP. TO 1ST SEMIAXIS Run stopped!
STOP REC HEIGHT NOT PERP. TO 1ST SEMIAXIS
Is there a numerical issue when producing REC bodies in FLAIR … or am I missing something ?
Markus
esps_exp.flair (61.8 KB)
