With the new FLUKA and Flair releases, will it be possible to incorporate the latest ICRP mesh phantoms into it, since ICRP mesh file contains .ele file? If yes, then is there any guidance regarding this?
Riya
Riya
Hello @riya,
indeed the latest ICRP mesh phantoms can be used in both tools. We have been doing this already for some time for a number of internal studies and tests as you can see below.
You might want to have a look at the manual:
8.4. Unstructured Mesh Geometry — FLUKA Manual
and the general guide on unstructured mesh geometries that was prepared by some colleagues: Guides | The official CERN FLUKA website
Chris
Dear @ctheis ,
Thank you for the response. I tried with .ele file and started creating the material and compound cards. I found that although the compound cards looks fine in FLAIR, but if I open the .inp in text editor there is some negative sign in some of the material name. I have installed .deb versions of new fluka and flair on ubuntu 20.
Riya
testMeshAdult_Ori.inp (4.6 KB)
Hi @riya
this is due to some mis-behavior/bug in flair and the fact you are using expressions to normalize to 100%.
Which you don’t need at all, since fluka is doing the normalization for you.
A quick way to implement the materials would be to open the Phits input of the ICRP145 in flair and select from the ribbon the drop-down menu to convert it to FLUKA. Then you will get all materials in FLUKA format
Dear @vasilis ,
I tried to do the following. I opened FLAIR, then selected phits in the option (see the attached image) and then tried to load the file MRCP-AM_external_input.pin. However, the attached error was generated. Can you please guide regarding this?
Riya
Hi @riya,
I am not sure but I suspect that the white-spaces in your path might be problematic. I would in general stay away from blanks in paths.
For further verification, could you maybe send me your .pin file via a private message?
Chris
Hi @riya
the Phits “TFILE” (tetra functionality) is not yet implemented in flair.
We’ve made a small patch in flair to bypass the error and load the input. Please (re-install) the latest version of flair (same version number)
On ubuntu it would be
$ sudo apt update
$ sudo apt install --reinstall flair
Then from the command line execute the following:
$ flair --page input -m phits MRCP-AF_external_input.pin
flair should load the phits input
Select from the Ribbon the “Phits” icon and change it to “Fluka”
This will convert the project to Fluka
You should have a FLUKA input with all the MATERIALS and other cards
Save and copy&paste the materials to your FLUKA project
Thank you so much for the guidance, it did save me a lot of time to create the input manually. Few things I have noticed after creating the input. It will be immensely helpful, if you kindly address them.
Riya
Hi @riya,
I had a closer look at the reported error and it seems to be a meshing glitch in the phantom that you can ignore. It’s an isolated vertex that seems to be in the data file but not used in the definition of the final tetrahedral elements. Thus, it is not a real overlap. I will have a look what we can do to improve the diagnostics for such cases.
Chris
Thank you @vasilis and @ctheis for the detailed response. I am thankful to the FLUKA team for this new update, was eagerly waiting for this feature to be available on FLUKA. I will try to generate AP, PA etc results with the mesh phantom to gain the complete understanding of the new utilities.
If you do find out the hidden flag in flair to sort them alphabetically, it will be nice.
And regarding the flair behavior, I am unable to place the new card automatically in the ordered manner (not only for this particular case, but in general as well), even if I select a range of cards (let’s say selecting all the cards), the flair is not putting it in an ordered location.
Riya
Dear @vasilis ,
I observed that to load this phits file, every time I have to reinstall flair, other wise I am not able to open the phits file using the command line
Is it the way out? The following error is getting generated:
riya@riya-VirtualBox:~/Desktop/MRCP_PHITS/External$ flair --page input -m phits MRCP-AF_external_input.pin
File "/usr/local/flair/flair.py", line 3573, in <module>
main()
File "/usr/local/flair/flair.py", line 3531, in main
project,_ = parseArgs(sys.argv[1:])
File "/usr/local/flair/flair.py", line 3297, in parseArgs
project.loadInput(filename, mode=forceMode, onlyinput=True)
File "/usr/local/flair/Project.py", line 4749, in loadInput
project = self._loadInputOrProject(filename, master, mode, onlyinput)
File "/usr/local/flair/Project.py", line 4888, in _loadInputOrProject
project.input.load(filename)
File "/usr/local/flair/deck/input.py", line 1287, in load
self.preprocess()
File "/usr/local/flair/deck/input.py", line 1031, in preprocess
self.refresh()
File "/usr/local/flair/phits/input.py", line 192, in refresh
card.refresh()
File "/usr/local/flair/phits/card.py", line 612, in refresh
self.loadUMesh()
File "/usr/local/flair/phits/card.py", line 619, in loadUMesh
self.loadExFile(fn+".ele", PhitsUMesh)
File "/usr/local/flair/deck/card.py", line 2720, in loadExFile
inp.load(filename)
File "/usr/local/flair/phits/card.py", line 629, in load
self.universes = set(super().load(filename))
TypeError: 'NoneType' object is not iterable
Dear @vasilis ,
I also noticed that in this new flair, in the material list, there is element Carbon instead of CARBON (this capital letter one was there in older flair version).
When I copied materials and compounds from phits, the material name in all the compound card is CARBON. Do I need to change it to Carbon? Or FLUKA is not sensitive to this?
Riya
That is bizarre, why to re-install? Are you sure you don’t have two flair installations in different directories. I would suggest to uninstall flair (and any other potentially in any other directory) and re-install it.
FLUKA is case sensitive to material, regions and bodies
Carbon do not exist in the pre-defined materials. It should be defined inside your input. unless if the conversion Phits->Fluka created that, however cannot find out where
Dear @vasilis ,
Please see the attached images for Carbon material. I have opened a fresh input with blank cards.
Riya
That material was there since long time, its not from Fluka but from the material database
