RUN ERROR_[.error] - No random file and [Status] - No running
FLUKA: 4-5.0 (released on 25/02/2025)
Flair: 3.4-3 (released on 08/07/2025)
Operating system: WSL
The first time, I got the error below.
**** No Random file available !!! **** **** If this happens in a multi-run sequence please **** **** check if any of the previous cycles crashed or **** **** stopped for some error, without producing the **** **** random number for the next cycle **** Abort called from FLRM64 reason NO RANDOM FILE Run stopped! STOP NO RANDOM FILE
So I modified the Cycle to 1 and modified the Randomiz card to run it, but I got the error like below.
!!! Seed file not accepted: or corrupted or main seed not matching the requested one !!!
I deleted all the .out .log .err files in the folder and ran flair again, just in case it was affected by the d drive,
run-run-start, but the status is not returning to '“not running”
I would really appreciate it if you could tell me how to do this.
Attach the file related to the input. Thank you.
O18_Water (1).inp (5.0 KB)
o18_water.zip (373.6 KB)
Dear @yjb,
According to the output files, you are using a FLUKA version which is not supported on this Forum.
To be able to receive help, please install FLUKA version 4-5.1 from https://fluka.cern/
