Dear all
This is a summary of errors appearing in different CR simulations.
It would be great for me if any one of the following could be solved.
are you ready?
par_split_30t_max :
(attached at https://drive.google.com/file/d/1cR9b_RRqR4OU-YOlsTgnCFqOh5O_MP8Z/view?usp=sharing).log: STOP IETAB > MXTBGE Note: The following floating-point exceptions are signalling: IEEE_UNDERFLOW_FLAG IEEE_DENORMAL STOP STOP: FLUKA ABORTED .err .out: *** Photon: have you got the right mat. data set? Abort called from SGTTEP reason IETAB > MXTBGE Run stopped! STOP IETAB > MXTBGE -
par_dpm_30t_max :
(attached at https://drive.google.com/file/d/1p7Fc9W7KnorCO8lENiwUjO7o7v_Ryfhc/view?usp=sharing).log Program received signal SIGFPE: Floating-point exception - erroneous arithmetic operation. Backtrace for this error: #0 0x7f353615038d in ??? #1 0x7f353614f5a3 in ??? #2 0x7f35357caf1f in ??? #3 0x5574000949ff in pho_abort_ at /shared/src/external/phojet/pho_abort.f:95 #4 0x55740005ad9c in pho_event_ at /shared/src/external/phojet/pho_event.f:155 ... #8 0x5573fff8d0d1 in dpmrun_ at /shared/src/external/dpmjet/dpmrun.f:66 ... #13 0x557400384b9d in flukam_ at main/flukam.f:2796 #14 0x5573fff758c0 in fluka at main/fluka.f:79 #15 0x5573fff758c0 in main at main/fluka.f:81 Floating point exception (core dumped -
earth_p_dpm_mono_30t_max
(attached at https://drive.google.com/file/d/19rg01Q24I34eM6d8pT_3XGrS11AWziiK/view?usp=sharing):
when WHAT(3)(4) of SPECSOUR card is set the same value, the fluence of all particles is zero.
then, how to simulate the fixed energy of primary particles in fluka? -
the fluence of neutrino and antineutrino of electron and muon is zero in any of my simulation.
if I miss something important? -
the value of geomagnetic field is zero when using flair plot check.
could you tell me why?
Thank you for your time. enjoy today.
Yi
