saman
(Saman Shahid)
17 September 2020 10:23
#1
Hi David,
Thanks for your reply.
I have now installed the mentioned fluka package. The message is coming: Congratulations all tests passed (see attached image).
Now, the previous output errors on starting up are not coming.
But, while running simulation, the software stucks a lot. Simulation run a bit, but then again the error: finished with errors comes (see images)
Kindly guide me.
Thanks
Saman
horvathd
(Dávid Horváth)
17 September 2020 11:29
#2
Dear Saman,
could you upload the input file (sam.flair) you are trying to run?
saman
(Saman Shahid)
18 September 2020 07:33
#3
Hi David
Kindly see the attached files. The simulations are running now with errors. sam.flair (1.1 KB)
thanks
horvathd
(Dávid Horváth)
18 September 2020 08:46
#4
Dear Saman,
your input file is knot running, because it is not complete. Please try to run the following example: example.inp (3.2 KB)
ceruttif
(Francesco Cerutti)
18 September 2020 09:19
#5
In particular, your geometry definition is patently wrong, from a conceptual point of view. You need first to study how a FLUKA geometry shall be defined.
