HI
I’m trying to run several projects in sequence with tsp but I don’t understand why once run they all become the same. How do I run several projects in series?
Thank you
HI
Thank you
Dear Andrea,
could you elaborate what do you mean under “they become the same”? Also please upload your flair project file, so we can have a look.
Hi david,
thanks for your help. I think I solved it with a pyhton macro. However, I had tried adding several projects in the run window, running them in tsp mode but once I ran the projects they all changed and became the same as the first loaded project.
Dear Andrea,
could you make a small example showing the issue, and step-by-step instructions on reproducing it? Thanks!
