I prepared a FLUKA input file with mgdraw.f by using USERDUMP. Also, I need to use flukadpm to include the special ion nuclear interactions. How could I compile, link and run with these two files simultaneously in a terminal?
Best regards, Kevin
Dear Kevin,
you can compile and link your user routine with the command:
lfluka -d -o <executable_name> mgdraw.f
The -d option will link RQMD and DPMJET as well.
-d
To run (5 cycles) from the terminal, you can use:
rfluka -N1 -M5 -e <executable_name> <input_file>
To see all the available options for these scripts, run
lfluka -h rfluka -h
Cheers, David
Thanks a lot!
