Dear Fluka experts,
I’m trying to run multiple cycles of the same simulation; I have done this using Flair in many occasion, the problem is that, since I have to run them remotely, I need to use the command line.
Following the instruction on the website, I used the command (for example)
rfluka -M 10 -e ./myfluka actual1-1-1.inp
The problem is that all the cycles yield the same results, as if the same seed was used for all of them… Am I making a stupid mistake here?
In the attached file you can find the input card, in case it could be relevant.
actual1-1-1.inp (8.8 KB)
