Sergey
(Sergey)
7 April 2020 20:45
#1
Hi! I try to run some .inp file using flair installing on Windows via docker. But there are not generated _fort.21 files when run is over. Also run finished during few seconds. This is strangely taking into account that there are generated 10E+9 primary photons. Can someone say why ? Here is .inp file.
Photoyields.inp (2.1 KB)
horvathd
(Dávid Horváth)
8 April 2020 06:11
#2
Dear Sergey,
your input file runs on my installation without any problem.
So, to find out what is wrong with your setup, you will need to look into the .err , .log , and .out files next to the input and in the fluka_xxx folder.
Sergey
(Sergey)
8 April 2020 11:54
#3
Here is error message
Abort called from FLRM64 reason NO RANDOM FILE Run stopped! STOP NO RANDOM FILE
horvathd
(Dávid Horváth)
8 April 2020 13:06
#4
Dear Sergey,
unfortunately it is not possible to tell what is the problem from only this error message. The other files should have other information as well.
Sergey
(Sergey)
8 April 2020 13:41
#5
Here are all .err files of discussed runnin
Photoyields001.err (476 Bytes) Photoyields002.err (82 Bytes) Photoyields002.err (82 Bytes)
horvathd
(Dávid Horváth)
8 April 2020 13:43
#6
Hi Sergey,
could you tell me, which version of FLUKA are you using?
Sergey
(Sergey)
8 April 2020 13:55
#7
When I did installation via cmd.exe there was automatically downloaded and installedd 2020.0.beta.2 version
horvathd
(Dávid Horváth)
8 April 2020 13:57
#8
Hi Sergey,
that version of FLUKA is not supported on this forum.
We only support the version distributed on https://fluka.cern/
Sergey
(Sergey)
8 April 2020 14:05
#9
I 've installed FLUKA using recommendations given here. How can I choose during installation the version of FLUKA I need ?
horvathd
(Dávid Horváth)
8 April 2020 14:10
#10
Hi Sergey,
to install the FLUKA version released by CERN, you need to follow the instructions posted on the https://fluka.cern/ website.
The procedure for registration is here: https://fluka.cern/download/registration
And the guide for installation on Windows 10:
https://fluka.cern/documentation/installation/fluka-flair-windows10-wsl
https://fluka.cern/documentation/installation/fluka-linux-macos
Sergey
(Sergey)
8 April 2020 14:16
#11
Is it possible to make installation on Windows7 using guide for installation on Windows 10 ?
horvathd
(Dávid Horváth)
28 April 2020 07:09
#12
Dear Sergey,
sorry for the late answer.
Now there is an option to install CERN’s FLUKA on older Windows versions.
The guide can be found here: https://fluka.cern/documentation/installation/fluka-flair-windows-vagrant
Please let us know, if you have any problem.
