Dear Experts,
I have installed the latest Flair and FLUKA version on a Centos7 cluster.
I managed to install all the Python packages requested (tkinter, pillow, scipy, dicom, …)
but still, I get this runtime error:
<<raise RuntimeError(“tk.h version (%s) doesn’t match libtk.a version (%s)”
RuntimeError: tk.h version (8.4) doesn’t match libtk.a version (8.5)?>>
I tried to install different versions of tkinter (8.5.13 and 8.5.19) as well as to use two different versions of Python3 (3.6 and 3.8.). I am using gcc.7.4.0.
Any help is highly appreciated.
Thanks in advance!
thank you for the quick reply!
No, I did not use pyenv.
The latest and default version of Python3 in my cluster is 3.6. With that version, after successfully running the installation command:
python3 -m pip install tk==0.1.0 --user --upgrade
I tried importing tkinter in a Python demo, and it couldn’t find the pkg.
Thus, I guessed it was a Python-version problem and installed Python3.8 (not centrally since I do not have root privileges) without pyenv: I configured the installation folder using: ./configure --prefix=… . The installation of Python3.8 went fine as well as the installation of all the libraries required for FLUKA/Flair.
With this Python version (3.8) I can import tkinter, but I get the error in the object.
unfortunately, it is almost impossible to solve your issue remotely since it relates to your Python installation. I suggest you contact the administrator of your cluster for help.
By the way, the command: python3 -m pip install tk==0.1.0 --user --upgrade is not for installing tkinter but some package related to TensorKit.
