RunTimeError when converting CAD file into UMesh
Flair: 3.4-5.2
Good afternoon,
I’m having trouble trying to perform CAD file conversion into an unstructured mesh by using the Python script FLUKA_mesh_fix.py. In particular, the following RunTimeError is returned (I installed Gmsh and MeshLib version 3.0.2.183):
user-be@macbe17169 geom_mesh_utils % python FLUKA_mesh_fix.py stellarator/Stellarator_Wendelstein.3mf
Reading from: stellarator/Stellarator_Wendelstein.3mf
Meshing without healing, errors to be identified…
Using OFF for meshlib conversion
Bounding box center for the full initial mesh: <meshlib.mrmeshpy.Vector3f object at 0x10ebf9a70>
Min. corner of the full initial mesh: <meshlib.mrmeshpy.Vector3f object at 0x10ebf9a70>
Max. corner of the full initial mesh: <meshlib.mrmeshpy.Vector3f object at 0x10ebf9a70>
Bounding box dimensions: <meshlib.mrmeshpy.Vector3f object at 0x10ebf9a70>
Mesh 1 has 764 nodes
Info : Reading ‘stellarator/tmp.off’…
Info : Done reading ‘stellarator/tmp.off’
Backup created at mesh_log.txt_20251126_161520.bkp
Bounding box center for the full initial mesh: <meshlib.mrmeshpy.Vector3f object at 0x117e3fc70>
Min. corner of the full initial mesh: <meshlib.mrmeshpy.Vector3f object at 0x117e3fc70>
Max. corner of the full initial mesh: <meshlib.mrmeshpy.Vector3f object at 0x117e3fc70>
Bounding box dimensions: <meshlib.mrmeshpy.Vector3f object at 0x117e3fc70>
File “”, line 1, in
from multiprocessing.spawn import spawn_main; spawn_main**(tracker_fd=8, pipe_handle=19)**
File “/opt/local/Library/Frameworks/Python.framework/Versions/3.13/lib/python3.13/multiprocessing/spawn.py”, line 122, in spawn_main
exitcode = _main(fd, parent_sentinel)
File “/opt/local/Library/Frameworks/Python.framework/Versions/3.13/lib/python3.13/multiprocessing/spawn.py”, line 131, in _main
prepare**(preparation_data)**
File “/opt/local/Library/Frameworks/Python.framework/Versions/3.13/lib/python3.13/multiprocessing/spawn.py”, line 246, in prepare
_fixup_main_from_path**(data[‘init_main_from_path’])**
File “/opt/local/Library/Frameworks/Python.framework/Versions/3.13/lib/python3.13/multiprocessing/spawn.py”, line 297, in _fixup_main_from_path
main_content = runpy.run_path(main_path,
run_name=“_mp_main_”)
File “”, line 287, in run_path
File “”, line 98, in _run_module_code
File “”, line 88, in _run_code
File “/Users/user-be/Downloads/input/geom_mesh_utils/FLUKA_mesh_fix.py”, line 516, in
file_path=process_meshes_with_error_handling(args)
File “/Users/user-be/Downloads/input/geom_mesh_utils/FLUKA_mesh_fix.py”, line 446, in process_meshes_with_error_handling
to_heal = detect_mesh_errors(to_heal)
File “/Users/user-be/Downloads/input/geom_mesh_utils/FLUKA_mesh_fix.py”, line 266, in detect_mesh_errors
with multiprocessing.Pool**(processes=1)** as pool:
File “/opt/local/Library/Frameworks/Python.framework/Versions/3.13/lib/python3.13/multiprocessing/context.py”, line 119, in Pool
return Pool(processes, initializer, initargs, maxtasksperchild,
context=self.get_context())
File “/opt/local/Library/Frameworks/Python.framework/Versions/3.13/lib/python3.13/multiprocessing/pool.py”, line 215, in _init_
self._repopulate_pool**()**
File “/opt/local/Library/Frameworks/Python.framework/Versions/3.13/lib/python3.13/multiprocessing/pool.py”, line 306, in _repopulate_pool
return self._repopulate_pool_static**(self._ctx, self.Process,**
self._processes,
…<3 lines>…
self._maxtasksperchild,
self._wrap_exception)
File “/opt/local/Library/Frameworks/Python.framework/Versions/3.13/lib/python3.13/multiprocessing/pool.py”, line 329, in _repopulate_pool_static
w.start**()**
File “/opt/local/Library/Frameworks/Python.framework/Versions/3.13/lib/python3.13/multiprocessing/process.py”, line 121, in start
self._popen = self._Popen**(self)**
File “/opt/local/Library/Frameworks/Python.framework/Versions/3.13/lib/python3.13/multiprocessing/context.py”, line 289, in _Popen
return Popen(process_obj)
File “/opt/local/Library/Frameworks/Python.framework/Versions/3.13/lib/python3.13/multiprocessing/popen_spawn_posix.py”, line 32, in _init_
super()._init_(process_obj)
File “/opt/local/Library/Frameworks/Python.framework/Versions/3.13/lib/python3.13/multiprocessing/popen_fork.py”, line 20, in _init_
self._launch**(process_obj)**
File “/opt/local/Library/Frameworks/Python.framework/Versions/3.13/lib/python3.13/multiprocessing/popen_spawn_posix.py”, line 42, in _launch
prep_data = spawn.get_preparation_data(process_obj._name)
File “/opt/local/Library/Frameworks/Python.framework/Versions/3.13/lib/python3.13/multiprocessing/spawn.py”, line 164, in get_preparation_data
_check_not_importing_main**()**
File “/opt/local/Library/Frameworks/Python.framework/Versions/3.13/lib/python3.13/multiprocessing/spawn.py”, line 140, in _check_not_importing_main
raise RuntimeError(‘’’
…<16 lines>…
RuntimeError:
An attempt has been made to start a new process before the
current process has finished its bootstrapping phase.
This probably means that you are not using fork to start your
child processes and you have forgotten to use the proper idiom
in the main module:
if _name_ == ‘_main_’:
freeze_support()
The “freeze_support()” line can be omitted if the program
is not going to be frozen to produce an executable.
To fix this issue, refer to the “Safe importing of main module”
section in https://docs.python.org/3/library/multiprocessing.htmlInput files
Do you have any suggestion to fix it?
Thank you in advance
FLUKA_mesh_fix.py (17.6 KB)
Hi Lorenzo,
Yes, this issue is fixable, and it was identified recently on macOS.
On this OS, Python multiprocessing and system sed work slightly differently from Linux.
I am attaching a dev version of the script that fixes this issue and provides other useful improvements.
FLUKA_mesh_fix.py (22.1 KB)
Please let me know if it solves the issue.
Hi Volodymyr,
thank you a lot for the script, it seems to work properly: I tried to use it to mesh the Stellarator-Weldenstein geometry and it worked.
It seemed to be working also in the case of the complex geometry (HiRadMat irradiation facility) I’m trying to model, but several hours after I launched the script, at the end of the meshing process, it returned me this error:
Info : It. 182000 - 60245 nodes created - worst tet radius 1.00406 (nodes removed 504 121251)
Info : It. 182500 - 60575 nodes created - worst tet radius 1.77902 (nodes removed 504 121421)
Info : It. 183000 - 60601 nodes created - worst tet radius 1.34393 (nodes removed 506 121893)
Info : It. 183500 - 60839 nodes created - worst tet radius 1.47814 (nodes removed 507 122154)
Info : 3D refinement terminated (58524226 nodes total):
Info : - 23474 Delaunay cavities modified for star shapeness
Info : - 122715 nodes could not be inserted
Info : - 594754 tetrahedra created in 6.34951 sec. (93669 tets/s)
Info : 33845 node relocations
Info : Tetrahedrizing 70767 nodes…
Info : Done tetrahedrizing 70775 nodes (Wall 0.973558s, CPU 0.960222s)
Info : Reconstructing mesh…
Info : - Creating surface mesh
Info : Found two nearly self-intersecting facets (dihedral angle 5.39369E-06).
Info : 1st: [26163, 26162, 26156] #587
Info : 2nd: [26163, 26162, 26164] #587
Info : The dihedral angle between them is 0.000309035 degree.
Info : Hint: You may use Mesh.AngleToleranceFacetOverlap to decrease the dihedral angle tolerance 0.05 (degree)
Error : Invalid boundary mesh (overlapping facets) on surface 587 surface 587
File “/Users/user-be/cernbox/UMesh_HRM/FLUKA_mesh_fix_MOS.py”, line 655, in
main**()**
File “/Users/user-be/cernbox/UMesh_HRM/FLUKA_mesh_fix_MOS.py”, line 601, in main
File “/Users/user-be/cernbox/UMesh_HRM/FLUKA_mesh_fix_MOS.py”, line 527, in process_meshes_with_error_handling
output_file=heal_and_remesh_meshes(to_heal)
File “/Users/user-be/cernbox/UMesh_HRM/FLUKA_mesh_fix_MOS.py”, line 508, in heal_and_remesh_meshes
finalize_and_write**(args,out_name, output_file,kernel = "geo")**
File “/Users/user-be/cernbox/UMesh_HRM/FLUKA_mesh_fix_MOS.py”, line 334, in finalize_and_write
gmsh.model.mesh.generate**(3)**
File “/Users/user-be/Library/Python/3.13/lib/python/site-packages/gmsh.py”, line 2189, in generate
raise Exception(logger.getLastError())
Exception: Invalid boundary mesh (overlapping facets) on surface 587 surface 587
As I understand it may be a problem of CAD geometry, do you have any tips to fix it?
I’d be particularly interested in modeling just few parts of the model, e.g. the dump parts.
Thank you in advance for the kind attention.
Hi Lorenzo,
Glad to hear that it fixed the issue with the meshing of the hands-on example.
Could you please share your CAD geometry (privately)? I can’t say anything without seeing it.
In general, from my experience, full-scale facilities contain a plethora of errors which may cause meshing issues.
