Save secondary particle information of neutrino incidence
Dear Fluka experts,
I want to get the secondary particle information which generated by neutrino for each event. So I used the USDRAW entry to save the secondary particle information(3d momentum, Energy, generating point) and modified the mgdraw.f file. But I have the following question.
1.In my mgdraw.f file, I opened a txt file called “Neutrino” , but there is no any txt output file was created after run.
2.I just found that the parameters of the vertex coordinates are called XSCO,YSCO,ZSCO from manual, but I don’t know the names of the parameters of energy and 3d-momentum of the secondary particles. Where can I find the names of these parameters?
There are my input file and mgdraw.f
mgdraw.f (10.0 KB)
neutrino.inp (1.1 KB)
Sincerely,
Dawei
Hello @sdw21,
You need to explicitly un-discard the neutrino transport (since it is by default switched off) for your input to generate results. Check in the manual the use of the DISCARD card, setting any of the WHATs to “-NEUTRIE”.
To properly get the information using USDRAW of the secondary particles I advice you to take a look at this and this post. The energy and momentum are obtained through ETRACK and PTRACK, respectively, as also detailed here. I think in your mgdraw.f routine you would also need to specify the output format properly to not raise an error, at first instance i.e. by using WRITE (IODRAW, *) … .
Taking a quick look at your input it seems that the TARGET region is not well defined and you probably also don’t need two USERDUMP cards.
Cheers, hope this is helpful. Don’t hesistate to ask further questions!
Andreas
Hello Andreas,
Sorry for replying so late. Thank you very much for your suggestions, I have read the talk you send to me. Now I change my input file and mgdraw.f, and the information which I need has been saved in a data file. But I still have some problem as following:
  1. I shoot 2GeV electron neutrinos into the water medium, but there are some electron neutrinos with primary information are recorded in the data file, does this mean that the source particles are also being recorded? And I shoot 100 neutrinos, but there are only 50 neutrinos with primary information are recorded, does that mean that only half the neutrinos reacted?
  2. It seems that all the secondary particles are recorded in the data file, but how do I know which particles are from the same neutrino, and are there any variables that can be used to determine that?
  3. It seems that every interaction is recorded, such as neutrinos scattering to produce electrons, which in turn cause electromagnetic showers. So how should I record only the particles directly produced by neutrinos, are there any physical quantities that can be used to make this selection?
There are my input file, mgdraw.f and output file
mgdraw.f (10.6 KB)
neutrino.inp (1.3 KB)
neutrino001_output.dat (67.3 KB)
Sincerely,
Dawei
Hello @sdw21 ,
To answer to your questions:
  1. I believe this is a result of the way you have now defined and use the BXDRAW entry for writing the data in your updated mgdraw.f routine. Perhaps it is more productive for you to stick to USDRAW as you did before and include the WRITE statement there, i.e. only write the data when an inelastic event occurs. This will also make your life easier for the next questions:
  2. As mentioned, you can take inspiration from this post to further detail the parent particle information. You can use the variables NCASE (the index of the primary source particle) to know which event history it belongs to and LTRACK indicating the particle generation number, i.e. a primary particle has LTRACK=1 and any secondary, tertiary, … particle has LTRACK>1.
  3. Hence, if in your mgdraw.f you select particles only secondary particles (LTRACK.EQ.1) originating from a primary neutrino parent (JTRACK.EQ.5).
Hopefully this helps, let me know in case you run into trouble.
Andreas
