I am scoring the production of Tc-99m via proton irradiation of a target, using RADDECAY, RESNUCLE, etc. When seeing the results the data does not show a column for this desired isotope, it shows Tc-99, Tc-100, among others. When I checked the manual it says " All residual nuclei are scored when they have been fully de-excite down to their ground or isomeric state"
Please, is there any way to estimate the production of Tc-99m using FLUKA? What is the suggestion?
The isomeric states should be printed in a table below the ground ones. Can you share your input so we can take a look in order to spot the problem?
Francisco
PS: keep in mind that, when activated using the RADDECAY card, FLUKA assumes an equal sharing between isomeric and ground states during production. In contrast, the different states are correctly populated during decay.
Most probably this is just because I ran your input using few primary particles to see if the isomers appeared in the results table or not. Make sure that you run with enough primaries to get statistically meaningful results.
