I am working on the simulations for the irradiation of a stacked foil of three different materials (e.g., Ni, Cu, and Fe). Therefore, to take an easy start I first designed a target of copper and irradiate it with a proton beam. To get the cross section value over various value of the energy, I used USRYIELD as I have shown in fig.1.
Here I have some confusion, I read the manual as well multiple lectures but I was not able to clear my understanding about
i. the lower (and upper) limits of the scoring limit for first quantity.
ii. I selected the second option in the kind whereas for the material cooper I also introduced an additional card as explained by Francesco Cerutti (Production cross section of 67Ga and 68Ga from interaction of Li7 beam on Cu target - #3 by ceruttif).
iii. The second major problem that I encounter is that how Francesco cerutti was able to plot the entire excitation function. Where as in the output of USRYIELD (sum.lis 49) I got only a single point of 387 mb.
I want the simulated results like Francesco Cerutti did here (Production cross section of 67Ga and 68Ga from interaction of Li7 beam on Cu target - #7 by ceruttif)
III. The third and the last question is that I want to get the a similar results for the three stack target at the same time i.e., for Ni, Cu, and Fe. How this can be done.
sorry for a lengthy explanation of my questions.
I will be thank you.
