Hi
I am using Ubuntu on a VM.
I had problems with flair crashing so decided to update to the newest version of Ubuntu - I still have the same issue…
I updated to Ubuntu20.4 and then had to reinstall flair. When I ran it, every time I opened geometry flair crashed with the error “Segmentation fault (core dumped)”
I uninstalled and tried to reinstall flair.
However when I did this I got the following error message…
(Reading database … 206734 files and directories currently installed.)
Preparing to unpack flair_3.1-4_ubuntu20.04_all.deb …
Unpacking flair (3.1-4) over (3.1-4) …
Preparing to unpack flair-geoviewer_3.1-4_ubuntu20.04_amd64.deb …
Unpacking flair-geoviewer (3.1-4) over (3.1-4) …
dpkg: dependency problems prevent configuration of flair:
flair depends on python3-scipy; however:
Package python3-scipy is not installed.
dpkg: error processing package flair (–install):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of flair-geoviewer:
flair-geoviewer depends on flair (= 3.1-4); however:
Package flair is not configured yet.
dpkg: error processing package flair-geoviewer (–install):
Processing triggers for shared-mime-info (1.15-1) …
Processing triggers for gnome-menus (3.36.0-1ubuntu1) …
Processing triggers for desktop-file-utils (0.24-1ubuntu3) …
Processing triggers for mime-support (3.64ubuntu1) …
Processing triggers for hicolor-icon-theme (0.17-2) …
Errors were encountered while processing:
flair
flair-geoviewer
…I am guessing there is an issue with python3-scipy in the flair code?
I am totally new to this so any help would be appreciated.
Thanks
Fiona
