Hello,
I need to install the latest version 4.0 on a RedHat Linux system.
I downloaded the file “gfortran 9, 64 bits (.tgz)”.
I did the installation following the instructions on the https://fluka.cern/documentation/installation/fluka-linux-macos page after loading the “GNU Fortran (GCC) 9.3.0” compiler and everything went very well, the binaries were compiled well.
But when I run the executable with the example.inp file (same with other cases), I get the following message: “Floating point exception(core dumped)”.
Looking at example001.log, it says “Program received signal SIGFPE: Floating-point exception - erroneous arithmetic operation.”
Does anyone have any idea if I’m the forgot something or if I’m doing it wrong?
could you post all the files generated, and the output of the rfluka command here?
Also could you specify which RedHat Linux version are using, and how did you load gfortran 9.3?
Great thanks for you, it solved the problem, you have the script output attached.
Mu colleague will be very happy !
I am now looking to flair and geoviewer.
