FLUKA: 4-5.0
Flair: 3.4-0
Operating system: WSL Ubuntu & Singularity container
I have been running my simulations locally on my computer so far. However, as the simulations have become larger, I want to move to a cluster. I successfully built a Singularity container following a previous post, adjusting it for my version of FLUKA. My container definition file (my_container.def) is attached below.
As a first test, I ran the basic FLUKA example inside the container on the cluster. The simulation completed successfully.
I used the following command (for a job array with 5 parallel runs):
singularity exec fluka_v03_20250731.simg bash -c “cd $WORKDIR && rfluka -M 1 $INPUT_NAME”
In a second test, I wanted to include a user routine (mgdraw). I compiled it in Flair, which generated a runfluka.exe executable. It worked correctly in my local FLUKA installation.
I then copied the executable to the working directory on the cluster and adjusted the run command as follows:
singularity exec fluka_v03_20250731.simg bash -c “cd $WORKDIR && rfluka -M 1 -e ./runfluka.exe $INPUT_NAME”
However, this time the simulation failed with the following output:
F L U K A
Dir: /usr/local/fluka
Data: /usr/local/fluka/data
Exec: /home/hd/hd_hd/hd_on296/FLUKA/20250731_test/runfluka.exe
Input: /home/hd/hd_hd/hd_on296/FLUKA/20250731_test/r04_01.inp
Error: /home/hd/hd_hd/hd_on296/FLUKA/20250731_test/runfluka.exe does not exist or it is not executable!
I confirmed that the executable is at the specified path. So I suspect that the executable is not recognized as executable in the container’s environment.
Now I was wondering if you could help me finding the problem. Do I need to include the compiled executable (runfluka.exe) during the container build process (and if so how), or is my singularity exec command incorrectly set up?
Any help in resolving this issue would be greatly appreciated.
Thanks in advance!
Stefan
Definition file for building the container:
my_container.def (1.2 KB)
Input file:
r04.inp (1.6 KB)
