Tell please what density value has the solid oxygen in FLUKA ?
Dear @s.amirkhanyan,
the default densities of the default Fluka materials can be found in the output file under:
=== Material compositions: ===
According to this the default density of oxygen is 0.00133 [g/cm^3]. Which implies that oxygen is treated as a gas by default.
I meant that I redefined the OXYGEN material by means of the MATERIAL card with density 1 g/cm3, as you can read in the input file.
