Tibe68
(Tibe68)
10 October 2022 09:02
1
Dear Experts,
when I try to run FLUKA using a fluence spectrum that I got from my experimental data, I get the following error message:
Error: “/usr/local/fluka/CERN-FLUKA-spectra-sampling/src/flukahp-spec” executable returned RC=255
Could you please tell me what does it mean?
All the best,
Tiberio
amario
(amario)
10 October 2022 09:14
2
Hi @Tibe68 ,
Did you have a look in the .out .log and .err files?
Tibe68
(Tibe68)
10 October 2022 10:09
3
Hi Amario,
thanks for answering so quickly.
This is what I get on the .out file:
- Running: Grating-30_blaze_13
Dir: /mnt/c/Users/ceccotti/Simulazioni_Fluka/Simulazione_grating
Cmd: /usr/bin/nohup /usr/local/fluka/bin/rfluka -e /usr/local/fluka/CERN-FLUKA-spectra-sampling/src/flukahp-spec -M 5 Grating-30_blaze_13
/usr/bin/nohup: ignoring input
Dir: /usr/local/fluka
Data: /usr/local/fluka/data
Exec: /usr/local/fluka/CERN-FLUKA-spectra-sampling/src/flukahp-spec
Input: /mnt/c/Users/ceccotti/Simulazioni_Fluka/Simulazione_grating/Grating-30_blaze_13.inp
Initial seed copied from /usr/local/fluka/data
Running fluka in /mnt/c/Users/ceccotti/Simulazioni_Fluka/Simulazione_grating/fluka_625
And this is the .err file:
NUMBER OF BEAM NUMBER OF BEAM APPROXIMATE NUMBER AVERAGE TIME USED TIME LEFT (RESERVED NUMBER OF STARS
PARTICLES HANDLED PARTICLES LEFT OF BEAM PARTICLES BY A BEAM PARTICLE 10000.0 SECONDS CREATED*
THAT CAN STILL BE FOR PRINTOUT)*
HANDLED*
NEXT SEEDS: 0 0 0 0 0 0 181CD 3039 0 0*
HANDLED*
Hope it helps…
Tiberio
ceruttif
(Francesco Cerutti)
10 October 2022 10:22
4
Hallo Tiberio,
it doesn’t. In fact, you did not look at the FLUKA output file (rather at the run output file, of limited interest), which is the one with the same name as the err and log files (i.e. ending with 001, or larger integers). I suspect that the log file is more relevant here, can you please search for it, in /mnt/c/Users/ceccotti/Simulazioni_Fluka/Simulazione_grating/fluka_625 or /mnt/c/Users/ceccotti/Simulazioni_Fluka/Simulazione_grating ?
Tibe68
(Tibe68)
10 October 2022 10:53
5
amario
(amario)
10 October 2022 11:13
6
Dear @Tibe68 ,
The log file you posted ends with this error message:
ERROR: The provided fluence spectrum is not contiguous and has gaps in the energy bin structure. Please provide contiguous bins without gaps!
I think it explains the crash.
Tibe68
(Tibe68)
10 October 2022 13:40
7
Dear Amario,
I think you’re absolutely right. My fault: I should have checked that…
Many thanks again.
Tiberio
