Hi, I am the beginner at FLUKA, and trying to calculate the yield of Ga-68. So, can you send the input card to me ?
Thank you vert much!
Dear @wangxiaohe,
I would recommend you to go through the material of the last Fluka training first and try to solve your problem by yourself before asking for help.
A couple of extra comments:
Dear Xiaohe,
The figure was produced running directly FLUKA’s interaction models by means of a dedicated driver which is not yet ready/foreseen for distribution.
One could attempt to use the USRYIELD card (in a thin geometry and using LAM-BIAS to effectively sample nuclear inelastic events in such scenario), but it is a bit cumbersome. Alternatively, still in a thin-geometry setup with LAM-BIAS, if one is well versed in the use of FLUKA user routines, one could intercept the desired final states (one neutron and 68Ga produced) in the USDRAW entry of mgdraw.f and keep track of the ratio of desired events to the number of nuclear inelastic interactions of the incoming proton, scaling this ratio with the reaction cross section in the end.
Being practical, since you’re interested in the case at hand, i.e. 68Zn(p,n)68Ga, you can simply make use of the figure I posted.
With kind regards,
Cesc
Thank you very much. I have try to learn the manual of FLUKA and write the input file by myself. However, the output is not what I expected. So, I want to learn the similar input card for check my input card.
Thank you very much for your advice.
Xiaohe Wang
Thank you very much for your reply.I will try using the USRYIEDL card.
Xiaohe Wang
