Dear colleagues, I am trying to implement the same modification to the FLUKA code as reported in this topic, for inelastic interactions.
In my setup, I have an electron beam impinging on a very thin target, and I want to bias photonuclear and electronuclear interactions just in that material via LAM-BIAS. However, I do not want to have the projectile being “cloned” in the final state. LAM-BIAS, by default, does that either via Russian Roulette or by always cloning the projectile in the final state, but with reduced weight.
I wanted to replicate the solution proposed in the aforementioned topic for \gamma N \rightarrow \mu^+\mu^- N, and thus I started to look at stupre.f and stuprf.f. According to the manual, stupre.f should be called when secondary electrons/photons are loaded in the stack, while stupr.f deals with hadrons, muons, …
I tried to understand more about this. First, I wrote a simple code for mgdraw.f that prints out all secondaries. This works properly, when the code is executed the secondaries from any interaction are printed.
ENTRY USDRAW ( ICODE, MREG, XSCO, YSCO, ZSCO )
IF (JTRACK.EQ.3) THEN
CALL GEOR2N(MREG,REGNAME,IREGERR)
PRINT *,"MGDRAW_1",ICODE,PTRACK,cztrck,REGNAME,NCASE
do kp=1,np
PRINT *,"MGDRAW_1_SEC ",kp,kpart(kp),plr(kp),czr(kp)
end do
END IF
I also modified stupre.f and stuprf.f as follows:
stupre.f
52 CONTINUE
LOUEMF (NPNW) = LLOUSE
c THE FOLLOWING IS THE MODIFIED LINE
PRINT *,"STUPRE.f called, TRACK:",JTRACK,PTRACK,ZFLK
500 CONTINUE
stuprf.f
200 CONTINUE
c THE FOLLOWING ARE THE THREE MODIFIED LINES
PRINT *,"STUPRF.f called IJ-NPSECN: ",IJ,NPSECN
PRINT *,"STUPRF.f TRACK: ",JTRACK,PTRACK,cztrck,Wtrack
PRINT *,"STUPRF.f GENSTK : ",KPART(NPSECN),PLR(NPSECN),czr(npsecn),wei(NPSECN)
Naively, I would have expected that, following an inelastic interaction, both stupre.f and stupr.f are called, if in the list of secondaries there are both photons/e+/e- and other particles.
For example, the following is the result of an interaction, as printed by mgdraw.f. There are 7 secondaries.
- The first is actually the primary electron, that is “cloned” in the list of secondaries (same momentum, same cz).
- The second is the final-state electron that is present in the interaction (interesting, different momentum but same cz).
- Then, one neutron and 4 photons.
MGDRAW_1 101 99.999184647158955 0.99999998433983484 MMPCB40 14
MGDRAW_1_SEC 1 3 99.999184647158955 0.99999998433983472
MGDRAW_1_SEC 2 3 99.980113297302054 0.99999998433983472
MGDRAW_1_SEC 3 8 2.4204667357567395E-002 -0.35656348784275327
MGDRAW_1_SEC 4 7 3.7739701897341865E-003 0.89226871675986441
MGDRAW_1_SEC 5 7 1.2530090283270269E-003 0.13674998267729363
MGDRAW_1_SEC 6 7 2.2254216640014818E-003 -0.87377399096657848
MGDRAW_1_SEC 7 7 6.4455971471241453E-004 -0.42476474927701219
I would have expected that there were 6 calls to stupre.f and 1 call to stuprf.f (for the neutron).
However, this is the result I see.
STUPRF.f called IJ-NPSECN: 3 1
STUPRF.f TRACK: 3 99.999184647158955 0.99999998433983484 1.0000000000000000
STUPRF.f GENSTK : 3 99.999184647158955 0.99999998433983472 0.99990000000000001
STUPRF.f called IJ-NPSECN: 3 2
STUPRF.f GENSTK : 3 99.980113297302054 0.99999998433983472 1.0000000000000000E-004
STUPRF.f called IJ-NPSECN: 3 3
STUPRF.f GENSTK : 8 2.4204667357567395E-002 -0.35656348784275327 1.0000000000000000E-004
STUPRF.f called IJ-NPSECN: 3 4
STUPRF.f GENSTK : 7 3.7739701897341865E-003 0.89226871675986441 1.0000000000000000E-004
STUPRF.f called IJ-NPSECN: 3 5
STUPRF.f GENSTK : 7 1.2530090283270269E-003 0.13674998267729363 1.0000000000000000E-004
STUPRF.f called IJ-NPSECN: 3 6
STUPRF.f GENSTK : 7 2.2254216640014818E-003 -0.87377399096657848 1.0000000000000000E-004
STUPRF.f called IJ-NPSECN: 3 7
STUPRF.f GENSTK : 7 6.4455971471241453E-004 -0.42476474927701219 1.0000000000000000E-004
STUPRE.f called, TRACK: 7 1.2530090283270269E-003 0.0000000000000000
Here, stuprf.f is called 7 times, for all the secondaries of the track that was printed in mgdraw.f. Then, I also see stupre.f called, but for a different track.
I am quite puzzled by this, since, as reported by the manual, stupre.f should be called when electrons/photons are loaded in the stack. Here, it seems stuprf.f is called instead.
Thanks,
Bests,
Andrea
