The run could not be finished using EMF-BIAS card with SDUM=LAMBEMF
when the emf_bias card with sdum=lambemf was used, the projection could not be finished.
here is the .inp file:
LambEmf.inp (1.4 KB)
the schedule for each core was not consistent.
Dear @Newconcept_1979,
Could you confirm me that in the runs that do not finish you observe in the .err file the following line multiple times?
     *** Electr: bremss.biasing not performed due to missing room in Emf stack ***
Let me know and afterward we can discuss the reason why you are observing this error.
Thank you,
André
@adonadon , sorry for replying later,
in the case, if the cycle for one core was finished, there was one .err file occured, but in the file, the comment “*** Electr: bremss.biasing not performed due to missing room in Emf stack ***” did not occur.
here is a .err file:
LambEmf_01001.err (22.4 KB)
if the cycle for one core was not finished, there was no .err file.
Interesting…
Don’t you get any output in the cases where the run does not finish?
André
@adonadon , Not any output files.
Did you check in the fluka_# temporary directories of the stalling cycles? I guess that you may find there the .err file with the aforementioned error message, which indicates that your biasing is excessive.
@ceruttif , yes, you are right, but why 2 runs of 6 finished, the other 4 runs can not be finished?
Because in a Monte Carlo simulation also biasing is a random process, which, based on your setting, exceeds the stack capacity with a certain frequency.
@ceruttif @adonadon , thanks!
