My fluka install in wsl following the manual and it worked fine a few days ago. But recently the flair windows disappear while my simulation is running.
The flair windows is fine while Pre-run model building and startup operations. But the flair window disappear after hours of running while there is no error or warning in the terminal. And I check the location of the simulation file, the running file is exist.
How to solve this problem?
Bonus question: My computer is 22 cores and 44 threads, but when running spawn over 36, some of the threads turn red (only 36 threads are running), what causes this?
Dear @ZhongLy
its hard to say why it disapears, especially when this happens without any error. I would suggest that you do the following. Run flair from the commmand line and enable the verbose output and log everything in a file like
$ nohup flair -v
it will create a nohup.out which will be populated with various messages. If the problem comes from flair maybe we can have a hint there what went wrong.
Since this one is a question on a totally different topic, I’d like to ask you to open a dedicated thread to address it. In this way the forum will be a more easily searchable place.
Additionally, I invite you to search on the forum for threads who addressed similar problems. A solution to your problem could already be available.
