FLUKA: 4-4.1
Flair: 3.3-1
Operating system: Windows 10 Enterprise
Compiler:
I am trying to run a simulation of a simple point source of Co-60 e Cs-137 inside a building and evaluate the dose in air spheres at different locations. I used many region around the building for setting different particle importance.
The simulation doesn’t start because of the following error message:
- Output file
Abort called from GEOFAR reason TOO MANY ERRORS IN GEOMETRY: STOP Run stopped!
STOP TOO MANY ERRORS IN GEOMETRY: STOP - Log file
Note: The following floating-point exceptions are signalling: IEEE_UNDERFLOW_FLAG IEEE_DENORMAL
STOP STOP: FLUKA ABORTED
However, the geometry doesn’t report any error message.
Thank you for your help.
Corrado
41i_tot.flair (7.3 KB)
41i_tot.inp (6.8 KB)
41i_tot001.out (133.0 KB)
source.f (9.1 KB)
